Turbo to Exhaust manifold studs ?
Postby donsladek » Sun 23.05.2010, 21:55
Anyone have the Isuzu part number for the turbo-to-exhaust manifold studs?
It appears this stud has 10mm 1.5 pitch threads into the exhaust manifold and 10mm 1.25 pitch threads for the turbo nuts, length is 42-43mm overall. I can't remove the nuts from the existing studs..
Also, has anyone used a 10mm 1.5 pitch double ended stud as a replacement, assuming the turbo nuts would be replaced by 10mm 1.5 pitch?
Possible stud?
Thanks!
Don Sladek
Calypso Red '91 #37594
donsladek
Re: Turbo to Exhaust manifold studs ?
Postby tte200 » Mon 24.05.2010, 12:41
donsladek wrote:Anyone have the Isuzu part number for the turbo-to-exhaust manifold studs?
Possible stud?
Thanks!
Have recently got these for Christopher Neil Cheshire. Not that expensive will get the part numbers and post when I get home.
Do remeber that removing the nuts from the studs was difficult (I used an imapct gun).
91 SE Turbo
tte200
Postby tte200 » Mon 24.05.2010, 20:55
Possible stud?
Thanks!
Sorry didn’t notice that you need the Isuzu part numbers, have the Lotus part numbers as below
A100E6436S Qty req’d 2
A100E6438S Qty req’d 1
A100E6437S Qty req’d 1
Hope this is of help to you.
91 SE Turbo
tte200
Users browsing this forum: Apple [Bot] and 5 guests
