by cliff » Thu 27.01.2011, 20:00
When I bought the car, my boost gauge was erratic. Sender was hanging loose, fitted correctly and boost gauge works fine now. During the test drive, I had hesitation when accelerating and a CEL light. I drove for 550 miles when I collected the car without any problems.
I thought that this sender was only for the indicator - please correct me if I am wrong.
For good measure have ordered the ElanScan interface so this should tell me more.
Any Ideas?
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
by lotusgirlmarie » Thu 27.01.2011, 21:16
You are correct in assuming the boost sender is solely for the gauge. You may want to do a paperclip test with the ALDL connector to see what code it gives. There is a write up of how to do this in the wiki link on the forum home page. Hope this helps
lotusgirlmarie
- Goddess
by cliff » Thu 27.01.2011, 23:08
Thanks, I looked at doing this but as it just started snowing, I put the car back in the garage.
A bit wimpish I know but at least I drove it with the roof down for the first time today.
07 Alfa Spider 939
cliff
