by Lotus54 » Wed 23.11.2011, 06:25
I seem to have a slight coolant leak. I haven't been able to pinpoint it yet, but it appears to be about at the turbo.
I recently replaced all the coolant hoses, so certainly it pressure on the metal hoses going to the turbo while fitting hose.
I can't tell exactly how they hook up to the turbo. Banjos and copper washers? Press fit?
Any tips I'd appreciate. Guess next is getting the car in the air enough so I can find it.
It takes a cople of days to loose 1/8 cup of coolant or so (maybe less amount)
Mark
1978 Benelli 750 sei, 1972 Benelli 175 Enduro, 2018 Beta Xtrainer 300
Lotus54
by Specky » Wed 23.11.2011, 07:20
An easy way to find the leak is to pressurize the system. See the photos in this
threadTTFN
by muley » Thu 24.11.2011, 22:58
Mark
They are banjos and copper washers - quite awkward to get at. The copper washers are 11mm or maybe 10mm.
HTH
by Lotus54 » Thu 24.11.2011, 23:16
Thanks for all the good info.
After jacking it up and crawling under, the drain plug and left hose we re slightly weeping. Fixed those, then let sit again.
Then found a slight one at the water pump connection. Tightened that some more, now I'll see how it goes.
It doesn't appear to be from the turbo at all, just pooled up right there. A bit of cardboard shoed the exact spot.
Guess trying to not over tighten the clamps resulted in under tightening ...
Tha is again.
Mark
Lotus54
