Wastegate porting without removing the turbo
Postby ashm » Sun 27.05.2012, 21:16
Evening all!
Question: has anyone ported the wastegate without removing the turbo? Seems a shame to take everything apart if I don't really have to...
Ad
ashm
Re: Wastegate porting without removing the turbo
Postby bobbrown » Sun 27.05.2012, 23:29
I would have though access would be tricky, you would have problems getting all the swarf etc out and there is a good chance you'll shear a stud on the exhaust elbow which is going to be a lot more difficult to get that out with the turbo still attached.
Just a few thoughts
Pacific Blue N/A
Postby ashm » Sun 27.05.2012, 23:47
I've taken the downpipe off with relatively minor difficulties; one stud left and it's turning, just not all the way out. Access to the wastegate is a little tight though. My biggest worry would be getting it properly cleaned out afterwards.
Ad
ashm
Postby Rice crispy » Mon 28.05.2012, 08:28
could you not put something inside which you could inflate (balloon) and cover in something sticky to catch the swarf then deflate and remove
Rice crispy
