by paulsmithmk » Wed 03.10.2012, 19:36
Hi All
few weeks ago I fitted mountain chip to my S2 - great change. On a drive home the boost stopped totally. I had it booked in for piper exhaust and downpipe to be fitted and had hoped it was just a broken cat (which it was) but there is still no boost. I can hear the turbo spinning up. RIP has kindly offered to hook it up to an elanscan on Saturday morning but I wondered if there is anything obvious I could try before then - I have wiggled the wastegate (still cant get that bottom bolt on tho!
thanks for any suggestions
Paul
S2 Number 640
paulsmithmk
by paulsmithmk » Thu 04.10.2012, 08:56
thanks - will visit bike shop this lunch!
S2 Number 640
paulsmithmk
by paulsmithmk » Thu 04.10.2012, 17:28
OK I am either doing something really wrong or there is a massive leak as I cant pressurise the system doing this??
S2 Number 640
paulsmithmk
by JonT » Thu 04.10.2012, 17:35
paulsmithmk wrote:OK I am either doing something really wrong or there is a massive leak as I cant pressurise the system doing this??
Sounds like a hose has popped off somewhere then. If it's not obviously the top hose, I'd try looking at the intercooler connections (NSF). You might need to get the car up in the air to have a chance of getting at these.
JonT
by paulsmithmk » Thu 04.10.2012, 19:07
Thanks - not sure where to start but as you say getting car on stands may help me see something off
S2 Number 640
paulsmithmk
by Steve A » Thu 04.10.2012, 19:21
I would start at the wastegate actuator and work backwards, it could also be a split pipe.
by paulsmithmk » Fri 05.10.2012, 18:38
Inter-Cooler pipe and popped off - getting to it a challenge but should all be ready for Goodwood and new Hispecs all fitted - happy boy!
S2 Number 640
paulsmithmk
by rip » Fri 05.10.2012, 19:23
Them pipe fixings take some stress, especially when running increased boost. Hope I can keep up on the way to Goodwood
by paulsmithmk » Mon 08.10.2012, 12:36
Car all sorted and drives as I had always hoped - stops well now Hispecs on
S2 Number 640
paulsmithmk
