by de_stanny » Mon 11.02.2013, 00:41
Hi All,
when i bought my baby there was an extra ecu with it and a box carton box from superchip with a chip in it .
Today i tought lets try the other ecu and it does work
it seems to be a std chip thats inside.... i didnt scan it yet ...
the original ecu has a superchip in it with nr 1344, but is seems to lit my boost to o,9-1 bar ....
the other chip in the carton box has a label T.P.S elan AVFK 0598...
googled like crazy already but ..... no result hopefully somebody can tell me waths in....
thx
de_stanny.
de_stanny
- Tinkerer
by de_stanny » Tue 12.02.2013, 00:35
Hi All,
After talking to the previous owner , it seems that the 2nd ecu is an original one , the extra chip is an original , and the superchip is coming from Superchip Inc in the US not from the UK that is explaining why the chip has a diff nrthen the 13121 we normally see on a superchip ,
Gave these people a call today for some tech support regarding the FCD... sorry sir we dont support your chip anymore .... to old product ... now thats service .....
anyone who could help me figuring this one out ? how can i see if the Feul cut off is active or not ?
grtz de_stanny.
de_stanny
- Tinkerer
by GeoffSmith » Tue 12.02.2013, 00:51
The Supershit chip is designed to work with an
MBC and is identical to a stock chip but without fuel cutoff. When the wastegate sticks closed, you'll be able to spin the wheels in second gear.
Been there, done that, got the T shirt, ripped out the hidden MBC and chip and converted to an Everest.
- Kitty Fiddler
by de_stanny » Tue 12.02.2013, 02:25
Hi Geof,
how do you explain then that we i increase my boost a bit, i get a CEL light ,,, when i check the code ...31 overboost ,
cheers,
de_stanny
de_stanny
- Tinkerer
by de_stanny » Thu 14.02.2013, 02:59
Hi All,
yes just to confirm , the supershit does cut the fuel if boosted to high .... had the issue today again... it seems there is a diff between the superchips from the 2 diff company's....
I even logged it with elanscan and yes i hit 0,92 bar and there came the engine check light .... code 31....
grtz
de_stanny
de_stanny
- Tinkerer
