Adaptronic ecu fitted and up and running
Postby m100sandra » Fri 29.11.2013, 21:03
The Elan will be back Tomorow from it stay with Chris at efiparts http://www.efi-parts.co.uk/northwest-rolling-road.php The dyno plots are below....
Its prob worth noting that the rolling road reads really accurate, i.e. Aimys VX220 Turbo St4 measured 286bhp at other places its recorded 300+ so i would guess it could end up around 250bhp on a diferent rolling road :roll: Chris as said that it drives really well.
Its back Tomorrow :-) :-) :-)
m100sandra
Re: Adaptronic ecu fitted and up and running
Postby HJ2 » Fri 29.11.2013, 21:36
Whohooo! No night sleep for you then :-)
You really have done a lot in a short time on your little Elan!
I can't wait the stories about the experiences with this latest mod 8)
Postby m100sandra » Sat 30.11.2013, 12:43
I did mean to mention the boost is turned down in 1st gear to to keep the mid range torque down, Rev limiter set at 7300rpm, Chris reckons it pulls strong beyond 7000rpm, 5000rpm rev limit until temps go over 60deg..
m100sandra
Postby m100sandra » Sat 30.11.2013, 15:30
A few pics showing the BEGI regulator (The stndard reg stays) & ASNU 550cc injectors :roll: :-)
m100sandra
Postby trig » Sat 30.11.2013, 18:42
Very nice 8) , hope it go's as good as it looks
trig
Postby m100sandra » Sat 30.11.2013, 18:57
Just been out in it, Flipping heck its fast :shock: No Turbo lag just smooth power upto 7000rpm, it does spin it wheels in 2nd but its cold out there, really pleased so i hope ime not going on & on to much :oops:
New Hybrid IHI Turbo,
Forge Actuator.
TurboSmart DV
550cc ASNU injectors,
BEGI Regulator etc.....
Adaptonic ECU (Mapped & fitted by Chris at efiparts)
Speedline 2112 GrA Alloys (Original wheels stored) KUMO KU35 215 tires.
Nitron Suspension.
HiSpec Brakes (Fr), RedStuff pads Fr & Rr
Stack Pro AFR, Oil pressure, Boost gauges
Shift light
Personal Grinta steering wheel
m100sandra
Postby rip » Sun 01.12.2013, 07:59
m100sandra wrote:i hope ime not going on & on to much :oops:
Not at all.
Interesting to hear that your new ECU has some extra features like reduced boost at cold temps & in 1st gear.
You will get wheel slip this weather. Tyres which we usually consider to be quite sticky don't work quite so well below about 10c. My daily is on winter tyres now because the front end was just starting to slide a little with the Toyo Proxes on there.
Postby Peter D » Tue 03.12.2013, 21:30
Keep posting your upgrades and experiences :porn:
Love it ... :burnout:
Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.
Peter D
Postby m100sandra » Wed 04.12.2013, 08:52
:-) I will
m100sandra
Re: Adaptronic ecu fitted and up and running with more bits
Postby m100sandra » Mon 16.12.2013, 20:36
A few more bits (non performance) to go on the Elan
m100sandra
Postby HJ2 » Mon 16.12.2013, 21:46
Waterdipped?
Looks ace! 8)
Postby mikeydude » Mon 16.12.2013, 23:47
water transfer printing.......so cool...
mikeydude
Postby trig » Tue 17.12.2013, 16:59
That looks fantastic 8)
What company did you use and how much does it cost ?
trig
Postby m100sandra » Tue 17.12.2013, 17:41
trig wrote:That looks fantastic 8)
http://www.wickedcoatings.co.uk/ The best way is to send them a picture with a tape measure next to the item you want coating and they will send you a price.... :-) They do all sorts of finishing.
m100sandra
Postby trig » Tue 17.12.2013, 19:51
thanks Sandra, ... just been looking at DIY kits as I would like to have a go myself , there is some tutorial on youtube that makes it look doable http://www.youtube.com/watch?v=wj6W7NQWPQo
trig
Postby m100sandra » Tue 17.12.2013, 21:01
I dont think anyone here would have the bottle :-) your right though, it does look doable.
The latest part that will need fitting :( (polished)
m100sandra
Postby m100sandra » Fri 11.04.2014, 16:54
Now fitted along with the quick shift 8)
m100sandra
Postby Elanlover » Mon 12.05.2014, 20:08
I.............want...............that.........engine!
:clap:
Postby L8apex » Sat 17.05.2014, 17:14
All the fine work you are doing on your car is making me very envious. The power curves from the dyno look really good and the AFR's are very nice. Which model of adaptronic ecu did you get? I went to their website but didn't see the M-100 listed in their lotus section. I live in the USA but I'm lucky enough have a local tuner who is quite gifted. He has done some stunning work on my Fiat 500 Abarth. I'm going to turn him loose on the M100 soon. He says there's only so much he can do with the primitive stone age ECU that came with the car. The adaptronic ECU appears to be just what he needs.
You seem to be doing some of the most interesting upgrades going on at present. It's actually a little bit inspiring. Please keep up the good work and post often.
I think it's time for me to open my wallet wide.
1991 red Elan SE
1969 S4 Elan SE coupe
2012 Fiat 500 Abarth
2007 Kubota B21 tractor with backhoe
Yes I know it's a tractor but it's a dam fine tractor
L8apex
Postby Elanlover » Sat 17.05.2014, 17:27
I wonder if there's a "kit" to ne had regarding the new ECU and programming??????
:poke:
Users browsing this forum: Apple [Bot] and 5 guests
