by novacaine » Sun 26.04.2015, 20:05
Hi All
Does anyone know the inner diameter of the vacuum pipe that connects to the boost transducer?
Mines looking pretty brittle and I don't want to remove it until I have the correct tubing in hand.
novacaine
by dapinky » Sun 26.04.2015, 20:18
I'm not really surprised that yours has gone brittle - the photo shows it to be kinked all over the place
Okay, then, I'll be serious - I used a 'standard' silicone vacuum hose with 3mm internal diameter - just make sure you get vacuum hose, not standard hose - it has a much thicker wall so it doesn't collapse under (negative) pressure.
I ended up changing all of my vacuum hoses whilst I was there, and I think it was about 7m in total (including the heater etc) - but if you only need a small bit, then it can be bought in half meter lengths for just over a quid - and a choice of colours. See ebay advert
here.
- LEC Administrator
by novacaine » Sun 26.04.2015, 20:32
The kinky pipe is down to my paint skills
I had that exact link saved in my watch list.
Thank you for the help Dapinky
novacaine
