Exhaust Manifold to Engine block Gasket -Replace or reuse.
Postby Ian_W » Tue 12.05.2015, 22:08
Have recently ported my wastegate to 22mm and have reused the exhaust manifold to engine block gasket. Seems to be blowing now though. Is this a reusable item as per the metal gaskets or do you need to buy a replacement.
Also have been trying to find the torque value for the manifold nuts, and the wiki suggests a certain order to tighten the eight nuts.
Thanks in advance for any help.
Ian W
Ian_W
