Elanchips
Elanchips
Postby paul27848 » Sun 14.02.2016, 22:56
Is it just me or does anybody else have difficulty in registering with the Elanchips site? The information requested seems convoluted and continually rejects passwords for a variety of reasons - not enough characters, need uppercase and lowercase, need at least one digit etc. Everytime I change to comply a different reason for rejection seems to appear.
Paul
paul27848
Re: Elanchips
Postby simonbuk » Sat 23.07.2016, 13:54
Just logged in, worked on the 2nd attempt. Password needs to be minimum 10 characters, and at least - one capital, one special character, and one number.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Elanchips
Postby V8vroom » Wed 27.07.2016, 11:03
Hello - just ordered a chip last week 20th July - anyone know how long I will be waiting? I know Mr Chip Man is busy doing other things normally, 4 chips were in stock and today its down to 2 so I guess others are ordering too... don't mind waiting but as I've paid already it would be nice to know an approximate eta??
cheers
Rupert
Lotus Elan S2 No. 513 Norfolk Mustard
V8vroom
Re: Elanchips
Postby simonbuk » Wed 27.07.2016, 17:07
Down to 2 ? Damn - better get my order in !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Elanchips
Postby B_land » Wed 27.07.2016, 18:11
V8vroom wrote:Hello - just ordered a chip last week 20th July - anyone know how long I will be waiting? I know Mr Chip Man is busy doing other things normally, 4 chips were in stock and today its down to 2 so I guess others are ordering too... don't mind waiting but as I've paid already it would be nice to know an approximate eta??
cheers
Rupert
Ordered when stock was around 8 and delivery was pretty quick, just over a week.
Not yet fitted but thought I'd better get 1 because new stock may disappear fast and new stock may not be for a while.
B
EG S2
B_land
Re: Elanchips
Postby simonbuk » Thu 28.07.2016, 20:03
I assume that when you are ordering a V4 chip you are automatically getting the later one ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Elanchips
Postby V8vroom » Fri 29.07.2016, 11:08
I think its out for delivery so will let you know what and when arrives!!
V8vroom
Re: Elanchips
Postby V8vroom » Fri 29.07.2016, 18:18
Hooray arrived today! Everest V4.5 will fit early next week!!!
V8vroom
Re: Elanchips
Postby V8vroom » Sat 06.08.2016, 21:16
So - first proper drive out today with new chip!
Felt fantastic - a real enthusiasm for revs and increase torque.... Definitely feels quicker and happier to rev!
Still getting cuts every now and then especially a quick up change from 2nd to 3rd with fuel cut.... So I suspect after a new chip and a wastegate wiggle I do need to 'port' the wastegate.... I will leave this to the experts at Kelvdon as I hope Mark there will be more than happy to help!
Thanks for all the help and support - I feel like I'm nearly there!
On a slightly separate issue in running green stuff pads but Kelvdeon were recommending the Pagid RS4 pads.... Anyone been able to compare these to green stuff?
Rupert
V8vroom
Re: Elanchips
Postby Rambo » Sat 06.08.2016, 21:35
The Pagid RS (blue) pads are fantastic compared to EBC greenstuff. The original Greenstuff pad compound was awful from cold and required the pad to be warmed up. They changed the compound to improve this but it still leaves a lot to be desired IMO. Probably still best suited for track days ??
You will pay a lot for the Pagid blue but well recommended
PS I have also found the EBC Yellowstuff pads to be much better for stopping from cold than the Greenstuff's (or Crapstuffs as I call them :? )
Re: Elanchips
Postby V8vroom » Sun 07.08.2016, 12:24
Thanks Rambo!
Based on our verdict I'll get some pagids then when they do the wastegate porting....
V8vroom
Re: Elanchips
Postby Artaban » Thu 25.08.2016, 16:10
Rambo,
I have the PNM Hi Spec front callipers. Do you know if the Pagid Blue RS4 pads, that they sell for the OEM brake callipers, would also fit in the Hi Specs? Kelevedon are looking into it for me but it would be handy to know if anyone had already put them in the Hi Specs without a problem.
Andy
Artaban
Re: Elanchips
Postby V8vroom » Fri 26.08.2016, 12:08
on this note just spoke to friendly chaps at Kelvedon who had not heard of the need to port the wastegate???? Mark is going to look at the car / Turbo when it goes in for a service in September.... will keep you all posted..
V8vroom
Re: Elanchips
Postby rip » Fri 26.08.2016, 15:13
Porting the wastegate is related to fitting a larger, more freely flowing exhaust, not a chip which gives higher boost.
This thread should give you a good idea of the dynamics behind it.
Re: Elanchips
Postby simonbuk » Fri 26.08.2016, 16:33
rip wrote:Porting the wastegate is related to fitting a larger, more freely flowing exhaust, not a chip which gives higher boost.
Eh ? No its not. Its enlarging the wastegate on the turbo to allow a quicker release of gases.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Elanchips
Postby Giniw » Fri 26.08.2016, 17:01
Mmm, Yes it is. Unless I am wrong ^^
The benefit of a larger bore exhaust is that the exhaust gases go out faster.
The direct consequence is that the turbo tends to spins faster, too. (*)
Of course the wastegate is supposed to control (limit) the turbo RPM by bypassing a certain amount of gases directly to the exhaust.
The problem is that the stock wastegate hole is too small for the larger gases quantity to bypass to compensate for a larger exhaust.
That means that under full charge the ECU can not really control the boost pressure, sometimes to the extend that it reaches its security limit, and the ECU emergency solution is to stop the petrol arrival.
* This is why a larger exhaust on the Elan is enough to gain a significant amount of power. The bad news is that it's not really controlled any more — unless one ports the wastegate of course.
Giniw
Re: Elanchips
Postby simonbuk » Fri 26.08.2016, 17:17
But if somebody says specifically 'port the wastegate' you don't expect them to go out and buy you a new exhaust ?
You expect them to enlarge the diameter of the wastegate.
I understand that you should also put a better exhaust system on if you have fitted an ElanChip and port the wastegate, all 3 should ideally be done for maximum benefit and prevent issues occouring.
*Unless of course I'm wrong*
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Elanchips
Postby Fredjohn » Fri 26.08.2016, 18:16
Aren't you both saying the same thing?
If you first fit a larger bore exhaust, you may then have to port the waste gate because the larger exhaust is allowing quicker release of the gases and the port can't cope. With a standard exhaust porting is not normally necessary. Therefore the porting is related to a larger bore exhaust!
Re: Elanchips
Postby Giniw » Fri 26.08.2016, 19:07
Giniw
Re: Elanchips
Postby simonbuk » Fri 26.08.2016, 19:10
Probably !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
