Exhaust manifold problem
Postby Danevansgolf » Thu 31.08.2017, 18:14
I've had my turbo/waste gate and exhaust manifold out for an overhaul, when putting everything back with new bolts/ gaskets etc, one of the stud holes connecting the turbo to the manifold has lost it thread.
What can i do to fix this problem?? Ie re thread?? Help needed as I need to fix this problem. Cheers all
Danevansgolf
Re: Exhaust manifold problem
Postby lotusflasherman » Fri 01.09.2017, 00:31
'Helicoil' is your solution, it's the original thread insert system that is now used as a generic term. Bit like most people hoover with a Dyson... :D
Do a Google search and you'll get lots of info and choices for helicoil kits.
Alternatively drill & tap for the next size up...
Postby Steve A » Fri 01.09.2017, 06:20
Danevansgolf wrote:I've had my turbo/waste gate and exhaust manifold out for an overhaul, when putting everything back with new bolts/ gaskets etc, one of the stud holes connecting the turbo to the manifold has lost it thread.
Has the stud left it's thread in the hole or the hole lost it's thread on the stud ? a photo might help
Postby lotusflasherman » Fri 01.09.2017, 09:37
Danevansgolf wrote: one of the stud holes ... has lost it thread.
Thought what was written was quite clear and unambiguous Steve, :smt017
Postby Steve A » Fri 01.09.2017, 16:38
:roll:
Yes but the question is has the thread been stripped from the stud or the hole, as it is an exhaust it most likely have seized and stripped the thread.
If it's just the stud then the hole could probably be salvaged by carefully running a tap/taps in the hole, but this isn't an easy job as the tap could snap giving you another problem :shock:
Helicoil would be too weak for this application, you'd be better off with something like this https://www.thorintl.com/Ensat-Self-Tap ... erts.shtml
a much more superior and permanent job. :wink:
Postby Danevansgolf » Sun 03.09.2017, 08:09
Defo the thread gone on the manifold. As I've got new studs going in. And I can see excess thread bits in the hole and the stud in perfect condition. Now to look for some helicoil s and figure out sizes. Cheers lads.
Danevansgolf
Postby Danevansgolf » Tue 05.09.2017, 15:48
Problem all fixed. Drilled out and put a thread insert in. Now to finish to job off, and get the car back on the road :D :D
Danevansgolf
Users browsing this forum: ludo and 1 guest
