by Oscarthecat » Sun 02.05.2021, 12:10
Hi all. As far as I am aware, the boost guage should be sitting at 0.0 when at idle. Mine is showing around 0.5. Could this be the transducer wiring needing a clean or possibly the wastegate sticking? I didn't want to start digging around and possibly making matters worse without asking advice first. Any suggestions would be helpful.
Paul
1992 BRG M100 SE
Oscarthecat
by Rambo » Sun 02.05.2021, 15:37
There should be no reading on the boost gauge when the car is stationary with the engine running. Only when you floor it when moving
First thing to check is the boost transducer connections. And check that the earthing point is good and clean
Have a look here....
http://wikilec.com/view/Boost_gauge_problemIt should be an easy fix
- Don't push me
by Oscarthecat » Sun 02.05.2021, 20:54
Thanks. I figured that was the most likely issue. All sorted now!
1992 BRG M100 SE
Oscarthecat
