How ALS works:
The ignition timing is retarded with 25-30° or more and the air/fuel mixture is made richer at low throttle opening and low load. With the ignition timing delayed, the air/fuel mixture reaches the exhaust tubes mostly unburned, because the exhaust system’s temperature is higher than the flash point of the air/fuel mix, the unburned fuel explodes in the exhaust tubes. The turbo is accelerated by the increased temperature/pressure and the rotational speed of the turbo is kept high. While ALS is engaged, full boost is available the moment the throttle is opened.
Some downsides:
An immediate increase in exhaust gas temperature (800°C to 1100°C+) whenever the system is activated puts greater demand on all turbo-system components - reliability becomes a major concern; the turbocharger and exhaust-manifold tubing must be made with the best available materials, driving the cost higher. ALS is prohibited from use in certain racing series.
