2 bar Boost Transducer.??????.
Postby delta » Thu 17.11.2005, 19:30
Installing a Haltech and upgraded turbo is a challenge, and with 1,3 bar boost I need a way to show it. I have found a 2 bar gauge, which can be delivered in red on black, but will also need a 2 bar boost transducer.
Anyone who know where to find that.?.
delta
Re: 2 bar Boost Transducer.??????.
Postby Dave M » Thu 17.11.2005, 20:34
delta wrote:Installing a Haltech and upgraded turbo is a challenge, and with 1,3 bar boost I need a way to show it. I have found a 2 bar gauge, which can be delivered in red on black, but will also need a 2 bar boost transducer.
Actually if you get a mechanical gauge, you can skip the headache of the transducer altogether. That's the route I went (did you do that as well, Sy?). The gauge was cheaper, it required a simple hose adapter to connect to the manifold, and it cleaned up the engine bay getting rid of the stock transducer. :wink:
Dave M
Postby Sy V » Fri 18.11.2005, 15:18
Exactly the same way as I went...no transducer for me.
Postby delta » Fri 18.11.2005, 18:45
Ok when, did you find a instrument thats fit and in same design and color :?:
delta
Postby Sy V » Sat 19.11.2005, 06:30
Oi you slippery Viking, Jorgen!
You've moved the goalposts. :wink:
Who said anything about colour originally. Both Dave and I have white dials. But I would imagine that a mechanical dial with red on black should be readily available. Just a matter of searching, I guess.
