by Andy C » Wed 28.12.2005, 08:52
Another of the issues with the M100 I viewed today was intermitent overboost.
About 50% of the time under hard acceleration the boost guage went spastic and off the scale with no engine management cut off .. the rest of the time it sat just above .5. From my readings at LEC I assumed dodgy wastegate, or leaking hose/cracked pipe, or some such. Are my assumtions the most likely cause, or could there be something more sinister (read: expensive).
Thanks again for your musings
A&J
Andrew
Medina Green #296 Brians Wilwood Brakes, Everest Chip, Piper 2.25, PWR Cooling & ProTech Suspension
Andy C
by Gazza » Fri 30.12.2005, 20:04
Mine had the same problem, soon as you started the car it went to 0.4 and then off the scale when accelerating.
It turned out just to be a loose earth.
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
by ESM » Sat 31.12.2005, 00:12
I agree, a bad earth on the boost gauge transducer is the likely issue. Its mounted on the bodywork at the left side of the engine bay and has a pipe connected to it from the plenum as well as a couple of wires: one to the mount and one to a connector on the back of it. The connection of the wire on the mount will probably be the problem.
ESM
by Doug » Sat 31.12.2005, 03:03
could also be a true reading if it has a BBR upgrade--you would know if it is true boost cause it should kick ass with the boost off the scale. but any erratic needle movement would suggest earthing problems with the sensor unit--so agree with above!
- LEC Founder
