Dear all,
Thanks for the pointers, have finally solved my low boost guage problem was very simple in the end. Firstly checked the connections on the boost transducer, cleaned it up a bit, reconnected and No Change, Had wastegate looked at no worries there, took the actual guage out cos the connections seem a bit loose the light kept flickerig, reconnected No Change, had the CAT chopped out and it was in good condition and have kept it in case of MOT Dramas but still no change although did seem to be a bit more spritely under hard acceleration. Ordered the drop in K & N and put it in this morning
What an improvement!!! lot quicker on the pickup and the fun guage registers on 0.5 now.
Having recently seen for the first time under the car had a look at the exhaust and i believe is time for a change so ordered the PECO exhaust that everyone raves about and is getting fitted next Wed all being well. Will be interesting to see how much of an improvement the Peco with the K&N is, opposed to the K&N with the bog standard exhaust with the CAT chopped out.
Will let you know.
Cheers to all.
P.S. Have got a taste for Blood now
Everest next me thinks!.
I fart in your general direction! You mother was a hamster and your father smelt of elderberries!"
Azure Blue S2 No. 452
