I purchased a set of intake pipes for the Elan from Top End Performance some time ago, installed it and have been using it without any issues. This package is essentially a steel pipe and K&N filter to replace the lumpy hose and stock air filter running to the turbo. It also includes a steel pipe running from the throttle body to the connector that runs to the intercooler (I assume). Mounted in the middle of this pipe is the blow off valve.
This valve is a bit noisy for my liking (silence is better) but I realize that any BOV will make some noise. I was calling around to see what could be done to reduce this noise. I initially thought I'd replace it with a recirculating BOV and plumb it back into the air intake so it won't vent inside the engine compartment and make noise. Bad idea I'm informed by Top End. That would cause the turbo to stall which is exactly what we are trying not to do. I hang up then think........Ok, what if I plumb it back through a hose and let it dangle in the old air intake area now open after removing the OEM air filter cannister...............
So, I call Turbo XS, the manufacturer of the BOV and explain what I'm trying to accomplish (reduce the noise essentially). He asks me a few questions abou the setup. I throw in (because I suddenly remember that I always wanted to ask this) "What does the nipple at the top of the BOV do???"
"What? he says. "It isn't connected to anything??" No I say, its just installed as it came out of the box. "Then its not doing anything at all for you right now". Apparently, that nipple needs a 6 mm hose running to the intake manifold (source of vacuum?). I'm worse than a newbie in this kind of discussion so........anyone know what this means?????????
Where would I run this too????? Should I run this somewhere????
Thanks all!
