Passenger door
Passenger door
Postby ansam » Fri 25.11.2005, 12:49
After I have lowered the pasenger window it does not come back up when the switch is pressed. The glass dislodges from the support mechanism. Is this a common problem if so has anyone a solution. Many thanks Tony
ansam
Postby Sy V » Fri 25.11.2005, 13:16
Yep, common problem. The glass is coming oft the spigot that goes through it. It is held in placeby a plastic 'C'-shaped clip/yoke which is notorious for breaking/coming off.
LEC Godfather
Return to Doors and Windows
