by Darren » Sun 11.09.2005, 09:58
I was advised a long time ago, that the motor was out of a Peugeot 405 of the same year. So since we don't have a local Peugeot breakers in my area I bought a left and right assembly off the Net.
So I confirm with a great deal of accuracy that the assembly in a Peugeot 405 ARE NOT the same as the ones in the Elan, ok, there are some items that look similar but you would't be able to do too much without a full stripe of the donor item etc.
Now unless someone can prove me different, I'm going to stick to my own experiances of wondering the breaker yard & confirm that our unit is a bespoke unit, made specifically for the Elan but using similar components to those used on other cars. As lets face it, would Lotus make a door to fit a motor assembly or get a motor assembly to fit the door ?
On the earlier subject of the motor rotation, the motor DOES rotate in both directions, this is controller by the two relays under the steering column (RHD). I can confirm that the I too have had a similar fault to the one you mention i.e where the window will only move in one direction, this turned out to be a faulty relay. So if I were you, I'd remove both relays from the working side of the car and replace them with the none working side. Or at the very least, swap them round (up & down relays), I'd also be inclined to check your switch etc. To conclude, if the motor goes one way, then it should go the other way also.
Owwwwww the connector into the motor can also be a little suspect.
I've got both doors to stripe out over the winter, as I've got a few new bits to try out, so I'll try and knock up a definative guide on window repairs.
Darren.
Open mouth, insert foot.
