Regulator Assembly - Has anyone got one
Postby Darren » Thu 22.09.2005, 14:32
Darren wrote: I can confirm that the I too have had a similar fault to the one you mention i.e where the window will only move in one direction, this turned out to be a faulty relay. So if I were you, I'd remove both relays from the working side of the car and replace them with the none working side. Or at the very least, swap them round (up & down relays), I'd also be inclined to check your switch etc. To conclude, if the motor goes one way, then it should go the other way also.
chris wrote:I have managed to get to the bottom of my window problem (only going down and not up). After stipping the motor down and replacing the brushes, replacing the broken plastic clip between the window and slide rail I have eventually traced the fault to the relay !
chris wrote:Total cost of repair including a few spares for next time....£30 + 1 day messing about.
Chris,
Aren't you forgetting my free beer in your £30 costs :wink: . ?
Darren.
Open mouth, insert foot.
Darren
Apology
Postby chris » Fri 23.09.2005, 13:36
Darren,
You're quite right I think you're owed the credit for this fix....and a beer if I meet you at Stoneleigh !
:oops:
Chris.
chris
Postby Sy V » Sat 24.09.2005, 05:57
Please don't coerce Darren with alcohol. We find it reacts with his Valium/Prozac/Viagra medication! :lol:
Return to Doors and Windows
