window Motor
window Motor
Postby GROMIT » Tue 09.02.2010, 16:43
Hi has anyone rewinded a window motor wire the bit that makes the window go up and down every time i try the wire gets stuck and stops i had to undo the wire is there a trick to it i have it on the slider and bow . how do u get it to wind evenley any help please i would like to have my window back thanks gromit
GROMIT
Re: window Motor
Postby Specky » Tue 09.02.2010, 19:47
I've done a few mister...
Specky's top tip.....
Use a bench vice and clamp the runner
use a spare battery and bench test it.... if it sounds like broken glass...you've crossed wires on the drum...
remove the long wire from the slider
Open up the drum lid, route the cable back on the drum (To do this, you'll need to keep tension on the wire to stop it bird caging and crossing over again, keep the tension on till back in the slider)
Put the lid back on the drum
place the cable back in the slider
bench test the little fella again
Hope that helps
This may help too....
Return to Doors and Windows
