Central locking or alarm issue?
Postby HUEANDCRY71 » Sun 28.03.2010, 18:22
Recently recharged the battery on my car after a month sitting in the garage and now the key fob will not activate the central locking.
I have tried both key fobs but still no joy, the lights on the key fobs work fine.
The central locking will work if i put the key in the door and close them manually.
The red LED in my centre console is flashing continuously when i am driving the car, not noticed it doing ths previously.
Any ideas what is wrong and what i need to do to fix please?
My 91 Elan in BRG is my 5th Lotus after previously owning a 111S,111R,Sport Racer and an NA Exige.
HUEANDCRY71
Re: Central locking or alarm issue?
Postby dapinky » Sun 28.03.2010, 19:10
As a guess, I'd say that the alarm has lost its settings due to flat batteriy???????
Depending on make/model of alarm, it can happen if the fob battery loses power, or the car battery is flat for an excessive period of time,
With my Vectra, it's just a case of putting the key in the ignition, switching it so the dash lights are on, then pushing alarm button to re-sync them.
On the Laserline on the red elan it is a little more complex, but doable.
On the Clifford on the blue car - havent a clue - it's never happened. :smt102
Try looking in alarm handbook, or on the website.......
....whatever the result, please bear in mind that this is a publically viewable forum, and anything specific to your car, or elans in particular is possibly not best put into general view :shock:
Postby RayD » Sun 28.03.2010, 19:16
As Dave says … and … the red light shouldn’t be flashing - it’s telling you the alarm has been activated – as it always does when you reconnect the battery - under normal circumstances it would be a simple matter of pressing the unlock button on the key fob to reset it but you need to re-program yours first.
Postby HUEANDCRY71 » Sun 28.03.2010, 19:19
dapinky wrote:As a guess, I'd say that the alarm has lost its settings due to flat batteriy???????
im not sure what the make and model of the alarm is to be honest, i do know that my car is a 91 SE Turbo and the alarm appears to be afactory fitted one. The alarm handbook doesnt describe resetting and isnt much help,i cant find anything elsewhere either.
Thanks for your response.
HUEANDCRY71
Postby HUEANDCRY71 » Sun 28.03.2010, 19:41
RayD wrote:As Dave says … and … the red light shouldn’t be flashing - it’s telling you the alarm has been activated – as it always does when you reconnect the battery - under normal circumstances it would be a simple matter of pressing the unlock button on the key fob to reset it but you need to re-program yours first.
how do i reprogramme it?
Just tried following the response below but that didnt work.
Cheers.
HUEANDCRY71
Return to Doors and Windows
