Now not winding right up
Postby Stef » Thu 21.06.2012, 14:01
Had to happen at some point I guess, but on my Birthday and after finding the rear calipers from SJ's I got fitted are leaking brake fluid, I'm not happy!
OK So passenger windo made a stuck and grindy noise as I wound the window up. No probs on it going down. Left a one inch gap from the top.
Have tried lifting and it won't budge. It still motors up and down but badly and not to the top!
Likely repair advice appreciated.
Shower cape will have to stay on and go with me now due to the nasty June weather :(
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Re: Now not winding right up
Postby Specky » Thu 21.06.2012, 19:02
Sounds like the slider has broken, the corner will be missing and thus will cant over and jam.
Replace the slider as per several threads on here...
There are hundreds of sliders going around... Mainly due to the Donny raffle last year.
Hope that helps
Postby Dave Eds » Thu 21.06.2012, 19:25
Thousands Specky! :-D
Postby Specky » Thu 21.06.2012, 19:50
I know.... :lol:
You wouldn't believe how many sets I've got...
And it's only because I overhaul the full assemblies for shits and giggles. LOL
Saying that I haven't done one for a few months.
Postby Stef » Fri 22.06.2012, 10:38
OK. The only write up I can find is in replacing the Regulator. Is this the same thing?
Figure I'll need the little orange/red clips too! :)
Sorry but I do need to be taken by the hand like a dunce here, I'm a techno dense chick! :-D
Stef
Postby Specky » Fri 22.06.2012, 12:24
Postby Stef » Mon 25.06.2012, 10:30
Cheers Specky, yes, hve seen and printed that write up!
Will post in parts wanted also, however, since in this thread, would there be anyone willing to sell their sliders if you have unwanted ones?
Thanks :D
Stef
Postby Stef » Wed 04.07.2012, 12:41
Me again...
Garage had a poke inside the door (and have temporarily wedged the window up with some wood secured inside) and say it's the middle part with the motor and winder that needs replacing.
The side runners seemed fine. Could someone please advise in what parts it seems I need to order?
Here are a couple of bits that were given to me:
Many thanks again! :D
Stef
Postby bobbrown » Wed 04.07.2012, 17:26
I got mine from SJ's
CLIP, (Butterfly) GLASS to REGULATOR A100B6271S £4.22
CENTRE SLIDE for WINDOW REGULATOR in left DOOR A100B6211S £2.75
if needed
DOOR LOCK BUTTON RED CLIP SJ100B0010 £0.81
Pacific Blue N/A
Postby Stef » Thu 05.07.2012, 12:33
Not rating SJ's at the mo but will check out the bits thanks.
What about the mechanism I apparently need?
Stef
Postby bobbrown » Thu 05.07.2012, 12:48
If you mean the whole of the motor assembly that's B100B0079F and is £217.00 inc VAT but looking at your picture it is more likely just the plastic parts that need replaced.
They are reasonably easy to replace assuming the cables are intact you just need to bend one of the stops out of the way to slide the centre slide on then bend it back, did mine on the drivers side a few weeks ago. POP
The parts in your picture should look like this
Left
Right
Pacific Blue N/A
Postby Stef » Thu 06.09.2012, 16:05
Update:
Had the two plastic bits replaced (butterfly clip and side block thing) but still grinding and not fully working.
Looks like the cable maybe frayed and needs replacing.
My garage isn't too keen having not done this before so I thought I would draw on LEC experts and put the job out to see if there are any willing volunteers?
You will of course be paid for doing the job!
Many thanks! :-)
Stef
Postby Specky » Thu 06.09.2012, 22:04
The grinding sound is normally caused by the wires crossed on the drum after someones tried to overhaul it, it'll require reloading properly.
Return to Doors and Windows
