Window stalls - Cracking Noises
Postby Simon_P » Sun 25.11.2018, 12:27
Hi All,
My passanger window goes up about half way then stalls accompanied by a cracking (plastic) noise. I helped it up but I suspect next time something will break.
I've heard of this before but can't find a relevant post. Anyone familiar with what is just about to break?
Re: Window stalls - Cracking Noises
Postby Brit-Car-Nut » Sun 25.11.2018, 13:54
On my car it was the slider that had cracked and would kick the window out of alignment causing it to stick.
Postby muley » Sun 25.11.2018, 16:21
Brit-Car-Nut wrote:On my car it was the slider that had cracked and would kick the window out of alignment causing it to stick.
Another vote for cracked slider... ..well it was on mine
Postby Simon_P » Sun 25.11.2018, 17:45
The middle one, ie the other half to the butterfly?
A100B6210S /11S
Postby Brit-Car-Nut » Sun 25.11.2018, 17:58
That is correct. You will need a butterfly as well as they can't be salvaged - They are a barbed, snap fit on the slider. See Wayne if you are not in a huge hurry.
Expect project creep via the
fuzzy wipers, A089V6166V;
Spacer Tubes, A100B1089K (See Dapinky's suggestions for Teflon rod instead);
Outer scrapers
and cleaning/lubing all moving parts.
Return to Doors and Windows
