by Graaf » Tue 28.01.2020, 12:26
Hopefully just a quick question...……
The drivers side door window sometimes refuses to rise when it has been fully opened but works OK when only partially opened.
Does anyone have any suggestions - other than don't fully open it
Is it something known or would just clean and regrease the runners?
Graaf
by AllenG » Fri 27.03.2020, 18:30
Hi, I had a similar issue. This worked for me, i removed the door card and loosened the nuts/bolts holding the window runners that they could move around a little. Then put the window to fully opened and tightened the lower bolts on the runners. Put the window fully up and tightened the upper nuts on the runners. This seemed to improve (in my case) the runner alignment and the window operated more smoothly.
AllenG
Return to Doors and Windows
