M100TURBOFR wrote:Thanks Joao & Jonathan for replying. Can see I'll just have to persevere. Jonathan would you have the link for these clips? Without actually seeing them, can't really understand their purpose! Do these clips secure window to slider block?
Attached photo shows block which inserts into slide rail. Is there not a "spigot" that goes through glass from behind and screws into the white round plastic which is flush with the window glass?
As glass not secured to slider block (front end) I now see why window glass got stuck and why regulator motor burnt out.
Thanks David
Saltire wrote:- on reassembly, never use normal grease on the runners. I used silicon spray.
Tuga2112 wrote:Saltire wrote:- on reassembly, never use normal grease on the runners. I used silicon spray.
now thats an interesting topic to dig into.
I wonder if "spray" is a good idea. as i was told it has a tendency to "soak up dirt"
I Have tried spray and my woindows are starting to jam just a year or 2 later.
silicone grease and white lithium grease are also options on my shelf. which i am thinkig of using te silicone grease next. and see what mileage i get. but not ruling out the possibility of white lythium yet
