Drivers Door Travel Limiter Mounting Point
Postby Virgin Dave » Mon 19.06.2006, 23:01
Evening All
Due to the 'clicking' when opening the door, I removed the A panel (the small one just in front of the drivers door with the side indicator mounted on) and replaced the rubber thingies with new ones. Job done, no more clicking. However, when having a general look and clean, inspected the point at which the door travel limiter is mounted to the chassis and found the area cracked which results an a 'spingy' door action.
As you can see from the photos it is a problem! Anyone got any suggestions?
If it's too loud, you're too old!
Virgin Dave
Postby Monty » Tue 20.06.2006, 10:46
Bloody hell,
Well thats only going to get worst and will rust away. Give it a good clean up and see if u can get it welded, might need to have a plate welded round it :?
Postby Virgin Dave » Tue 20.06.2006, 12:41
Hi Monty
Thought as much. I will need to strip it down and get it straightened first, so I think a job for the winter!!
Just wondered if anyone else had a problem like tis!
Virgin Dave
Return to Doors and Windows
