Ahem and goodnight...
Postby sideways » Wed 07.08.2019, 22:49
That's what it said yesterday - ahem - and then went to :asleep: as I was noodling through a car park in 2nd gear at low speed.
I depressed the clutch and did a bump start, yes I know, naughty but...fired up just fine.
Did it again as I was idly idling at the lights, started it on the key this time.
Saw the revs drop last week when I pushed the AC button.
So - Filter? Fuel Pump?, - (definitely(?) wasn't electrical as it slowly went :asleep: .
Not a big concern as I don't drive it as often as I could - but I do drive it often enough to blow away the cobwebs, move the fuel from tank to engine and rarely putter around other than in car parks.
sideways at speed
Delta BC Canada
sideways
Re: Ahem and goodnight...
Postby Simon_P » Wed 07.08.2019, 23:41
I had a similar issue recently with the Blue Car. Often when I approached a junction or traffic lights it would die. It turned out to be the vac hose had come off the non return valve for the evaporative emissions system. I must have knocked it off when I changed the oil filter.
Return to Engine
