A tale of torques... (timing belt etc)
Re: A tale of torques... (timing belt etc)
Postby madbilly » Sun 14.04.2019, 20:44
Phew!
I finally got it all done, whoop! That took about 5 months - is anyone tracking record times for completing jobs?!
Getting the right tension on the drive belts proved quite irritating, I was never happy but decided to just try it and see. During the test drive it all sounded good, no whining.
The tip I read somewhere about putting the space saver on the front-right side of the car for good access to the crankshaft bolt was very helpful.
Only real problem I have now is working out why I have a ~1/4" ball bearing and a ~4mm diameter ~1cm long spring left over! :? They were lying underneath the car when I finished and I cannot figure out where they might have come from.
I hope my next job doesn't take as long... but during the test drive I realised that I need to get new suspension - I reckon that will at least all of next winter! :cry:
Cheers :)
madbilly
Postby HJ2 » Sun 14.04.2019, 21:35
You can find a spring in the belt tensioner...
Postby madbilly » Mon 15.04.2019, 08:07
Hi HJ,
That's a long one though isn't it? ~1cm diameter and ~5cm long? I definitely put that one in! :D
If I have time tonight I will take photos and measurements. I just had a search through the parts list and I can't see anything which I think corresponds to this spring, never mind the ball bearing. Maybe the ball bearing is from my bike maintenance...
Cheers :)
madbilly
Postby lotusflasherman » Mon 15.04.2019, 15:48
madbilly wrote:Hi HJ,
Cheers :)
If it's a small spring and ball bearing check your socket tools - they have a spring loaded 'captive ball' to hold the socket on ... some of mine have escaped from well used tools.. ( Now wait for the Rambo comment about my 'well used tool' ... :lol: )
Postby HJ2 » Mon 15.04.2019, 15:55
Sadly the spring in my tool is gone as well...
Postby madbilly » Tue 16.04.2019, 08:43
:lol:
Good tip, thanks, I'll check my socket wrenches.
Cheers :)
madbilly
Postby GeoffSmith » Thu 12.03.2020, 22:52
Another one for the Beck/Arnley crap casting club. I found that attaching the pump by the top right hand bolt then rotating the pump clockwise is the easiest way to confirm and is easily solved with a Dremel.
WikiLEC updated before I forget.
Postby dapinky » Thu 12.03.2020, 23:07
I have to say that the Gates unit I fitted last week was identical to the Aisin (OE Isuzu) unit I removed......
.... it went straight in without any issues.
Return to Engine
