remove crankcase ventilation valve fitted in cam cover?
Postby raphsolo » Sat 03.06.2017, 13:52
Hello !
My crankcase ventilation valve (fitted in cam cover) is broken in the middle...
But i can't remove the part in cam cover ???
How to do it ?
Thank's a lot !
Lotus Elan M100 turbo SE 1991 racing green - Lotus Elise S1 azur blue
raphsolo
Re: remove crankcase ventilation valve fitted in cam cover?
Postby Simon_P » Sat 03.06.2017, 17:22
It's just a plastic pipe with a rim (like the other end) pushed into a rubber grommet.
Put a screw or hook up the middle and pull it out.
Postby lotusflasherman » Sat 03.06.2017, 18:41
Simon_P wrote:It's just a plastic pipe with a rim (like the other end) pushed into a rubber grommet.
:agree: probably the grommet has gone hard as rock and won't let it go so needs cutting off and replacing... sharp chisel and big hammer job .. Wham bang, job done ... :lol:
Postby HJ2 » Sat 03.06.2017, 22:37
... thank you ma'am :bananasex:
Postby raphsolo » Sun 04.06.2017, 16:54
Yes...very hard...so i need to cut it....but it's plastic tube inside a plastic part !
THere is a plastic part on the cam cover, the crankcase go inside...is it possible to get out this plastic part ?
Thank you !
raphsolo
Postby Elantastic » Thu 29.04.2021, 13:51
Has anyone had to take the cam cover off to get the piece of broken PCV rubber grommet that’s inside?
Elantastic
Postby HJ2 » Thu 29.04.2021, 13:54
No, but for a head gasket replacement... yes!
It is not difficult and depending on the age of your cover gasket you could even re-use that, so no cost involved.
if you do: Don't over-torque! (then there are cost involved... :shock: )
Postby GeoffSmith » Thu 29.04.2021, 14:45
Elantastic wrote:Has anyone had to take the cam cover off to get the piece of broken PCV rubber grommet that’s inside?
Yes. :evil:
Postby Elantastic » Mon 03.05.2021, 14:26
HJ2 wrote:No, but for a head gasket replacement... yes!
Thanks for that about to attempt in now, I actually got the pipe out without the grommet but for some stupid reason I felt compelled to take the grommet out as well. I’m hoping it’s fallen somewhere easy to see once the cam covers off!
Thanks for the response will be attempting this shortly. Fingers crossed the gasket is still useable.
Looking at the manual it says we need to use a silicon gasket sealant in certain spots although the picture in the manual is a bit difficult to work out the length and where the beading is meant to go I’ve seen a thread where some have said put some on the sharp edges near the cams ? Maybe it will become clearer when the covers off.
Elantastic
Postby HJ2 » Mon 03.05.2021, 14:45
Only a dot of rtv in the sharp corners for the recess of the cam shafts is enough. :burnout:
Postby GeoffSmith » Mon 03.05.2021, 15:57
Elantastic wrote:…I felt compelled to take the grommet out as well. I’m hoping it’s fallen somewhere easy to see once the cam covers off!
I tried to retrieve mine with a vacuum cleaner and some bent wire but didn't quite manage it. It ended up caught behind the baffle in the cam cover but was easy to get out.
Postby Elantastic » Tue 04.05.2021, 19:06
HJ2 wrote:Only a dot of rtv in the sharp corners for the recess of the cam shafts is enough. :burnout:
Thanks HJ, from looking at the Gasket you must mean these sharp edges :cheers:
Elantastic
Postby Elantastic » Tue 04.05.2021, 19:09
I managed to shake the remains of it out of the baffles, it was like playing 'roll the ball' but with half a grommet just without being able to see the grommet.
Elantastic
Postby Elantastic » Tue 04.05.2021, 19:13
I was thinking of trying to clean the cam cover up in an ultrasonic cleaner lots of dried burnt oil on the inside...but in not sure whether the Ultrasonic waves may damage the finish of the metal or remove the paint, anyone had any experience with that? Thanks for the responses, just need to order a new PCV valve grommet from SJ's and try and clean the inside of the cam cover and its good to go again.
Elantastic
Return to Engine
