Fumes in Cabin
Fumes in Cabin
Postby pte123 » Wed 12.08.2026, 13:12
Hi, I wonder if someone could help. I'm getting engine fumes into my cabin. I just purchased the car about a month ago. Doug on the M100 facebook suggested I look on here for a thread by Marie, but I've looked a lot and can't find anything.
I looked in the manuals and I think the air goes into the cabin though this area on the passenger side (I have a Fed LHD car). It looks like someone has installed a rodent stopper here. Am I missing anything that may help blocking the engine fumes?
Help appreciated!
pte123
Re: Fumes in Cabin
Postby TorqueHorse » Thu 13.08.2026, 05:12
Sorry to hear about the fumes. Well the engine bay doesn't even smell like engine fumes, so that is weird. Maybe your evaporative emmisions control canister is leaking? That is under the plastic tray that the convertible top rests in. Are the fumes when it is at rest, or when you are driving? I assume top up and windows up? Are the fumes stronger in one area over another?
'91 FED M100 -rolling resto
Re: Fumes in Cabin
Postby pte123 » Thu 13.08.2026, 15:55
Thanks Matt. I'll do some more investigating. One thing for sure is that I haven't had the top up since I had the car, hence one of the reasons why I thought it was coming in through the air con (I did have that on as it's been over 90 degrees in Boston) and I've mainly been around town. Cheers!
pte123
Re: Fumes in Cabin
Postby simonbuk » Sat 12.09.2026, 12:05
What fumes though ? Exhuast fumes ? Hot engine fumes/smells ? Petrol fumes ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Fumes in Cabin
Postby tigerdog » Mon 05.10.2026, 19:24
That's the one! The "rodent stopper" is (I believe) simply the remnants of what should be a complete hose/duct that allows fresh air to be drawn in. The remainder was probably foam that self-destructed over the years. I can't seem to find the post to which I referred... but I did end up buying a replacement from LGM, back in the day. At any rate, here's a picture and the official part number:
A100P0096F Foam Connector, HVAC wheel arch duct to plenum
[img]
[/img]
Re: Fumes in Cabin
Postby dapinky » Tue 06.10.2026, 09:15
If you want to avoid having a bit of foam gradually degenerating ain the future it is possible to fabricate a suitable item using a piece of rubber inner-tube from a tire (I used motorbike one, but anything will do)...... just wrap it round the join , add a smear of rubber glue along any joints and a cable tie at each end - job done!
Return to Engine
