fillpoke wrote:My Elan is off the road for the winter but gets a drive of 10 miles or so every couple of weeks (weather permitting) just to keep things turning. After the drive today I noticed the temperature gauge reading quite high on idling (it's always on the first gradation when running) and going even higher until the fan cut in. It then fell back to the middle gradation before climbing again until the fan cut in once more. The oil pressure also looked a bit low to me. I've posted pictures so you can see what I mean. What do you think? Should I be worried are these normal readings?
rip wrote: Sudden pressure loss while driving is entirely different
Rambo wrote:rip wrote: Sudden pressure loss while driving is entirely different
I agree. Very serious
I took the red one for a blast and oil pressure was very good. 2.5 bar at idle (engine warm), 5 bar or just under when driving
Simon_P wrote:HJ2,
Yes fixing the root cause is always best.
Thicker oils are OK for noisy tappets and leaks but not sure what other benefits there are. Yes 60 oil will give higher pressure but what advantage is that?
Simon_P wrote:Lotusflasherman,
I understand the viscosity ratings but still not convinced that thicker oil and higher pressure are good.
Higher pressure correlates to increased work and reduced flow rate. A 30 grade oil maintains the bearing film thickness while the oil also has to lubricate the cylinder walls piston rings and valve guides as well as cool the pistons. There is no pressure there and a 60 oil isn't going to get to places that were designed for a 30 oil to reach.
