dapinky wrote:The insert pushed out with finger pressure easily.
Monty wrote:Don't think i would recommend removing the metal ring as it's very close to another hole only IMHO, i removed the locating dowel on that side. It's wierd that one locating hole fits but the other doesn't
geoffsmith wrote:Monty wrote:Don't think i would recommend removing the metal ring as it's very close to another hole only IMHO, i removed the locating dowel on that side. It's wierd that one locating hole fits but the other doesn't
If you check out Mark's colour coding, it's only a bolt hole next to it and there is a seal around both so I don't think it's a problem. Like you, I was sceptical but yet again Pinky is right!
dapinky wrote:I had the same issue with the one i used (NOT from kmc, but from USA, destined for an impulse turbo). i can only assume that Lotus used a slightly different head locating dowel system than Isuzu,
paulwatkins wrote:The issue here is that the head gasket supplied as part of kmc's kit is DIFFERENT to the Lotus branded head gasket.
geoffsmith wrote:Think you're right Monty. I was talking bollocks.
