Yep, sorry, I reckon you've gotta bite the over-rev bullet...
Your air:fuel ratio becomes okay-ish after a couple of mins. If you ever decide to go 1499/closed loop your fuel mix pot doubts get taken out of the equation...just sayin'...
chrism wrote:Is this what you need Tuga? Mine + pal's are pink + black respectively.
Car up to temp, fans kicked in a couple of times, stuck the good old paper clip in to activate service mode and brought the revs up to 2000 rpm and let them drop down slowly. Looks like timing was around 10TDC. Adjusted and got it to around 16TDC (timing mark was jumping around a bit). Still idling high. Turned the idle screw in to the point of where I can’t go any further. Idle speed achieved is around 1100rpm. Disabled service mode and she sits there and idles around 1100. Doesn’t sound happy though. Maybe firing on 3 cylinders.:
When performing the old paperclip test and starting the car, she runs perfectly at around the 950-1000rpm. Could this be another sensor? I have a throttle position sensor on the way.
Tuga2112 wrote:the running theory in my brain (and i suspect most people trying to help) is that theres more air in the plenum than should be, and the ECU is adjusting everthing else to prevent damage.
dapinky wrote:Aarrrgggghhh! - I wrote a longish reply and then it disappeared!!!!
I'm now approaching from a slightly different angle to see if it helps the 'hive thought process'.....
Starting with the "knowns":-
The engine will start and run under its own settings whether hot or cold - so that means that it can satisfy the 4 conditions required to get that far (even if not in the right proportions).... Air, Fuel, Compression & Spark.
At that point, the idle rapidly increases to 3-4K revs (Is it an instant 'jump' or a slightly more gradual increase over a few seconds - ie, is it like a throttle opening quickly, or a gentle foot down increase?). where it will remain.
It stays at that point whatever the engine temperature gets to, and the temp behaves in a way that would be considered normal(ish).
There are believed to be no vacuum leaks (and even if there were, we wouldn't expect the idle to be this high - maybe 1200 - 1800, but not 3K+)
The MAP sensor has been changed and the part number (and ES graphs) suggest that it is the 'right' part.
The IAC valve has been changed twice without any change to the running, so it is reasonable to expect it to be a 'good' unit........ (what about the wiring to the IAC?)
The ECU has been changed (or am I imagining that part?) with no consequence.
The coil base plates may or may not have been wrong, but are now as per the Manual.
Now lets go to the 'thoughts' and "unknowns".....
For the idle to go that high, the engine requires a fairly high air supply (the fuel is provided to match the air, and controlled by electronics, and appears to 'match' the requirements)..... so where is this air coming from?? and how high a volume is at actually getting into the plenum?
At no point should the turbo or its pipework really come into it, as the car does this well before the 'turbo actuation' parameters are met (90degC, 2,800 revs, 50%+ Throttle)
so - what happens when you try to drive the car? Does it require ANY throttle input to keep the revs at 3K, or does it drop immediately you let the clutch out and add load to the engine? Does the engine (whilst driving) respond to throttle changes/inputs as would be considered 'normal'? (is it driveable, or uncontrolled running??).
