muley wrote:
I followed the Wiki and John W's excellent cam pulley holder thread.
muley wrote:Good tips on the allen key - I actually had one in a Halford ratchet handle set that did the job perfectly!
muley wrote:There didn't seem to be any way to remove the upper cambelt cover without getting the pas pipe out of the way, so I undid the PAS pump bolts and shifted it forward to get the pipe out of the way.
muley wrote:If you remove the socket screws and the PAS pump - there's no need to undo the 3 bolts to the engine mount.
muley wrote:An easy way to drain the PAS fluid it so undo the pipe clip at the pump end and pull the pipe off - the fluid comes out easily!
muley wrote:The reason why the manual says set the tension at 60 deg ATDC is because at the point both camshafts can spin - they're not holding valves open.
muley wrote: p.s. Don't do what I did and get the alternator belt wedged between the cambelt and adjuster pulley as you wind the engine on to TDC!!
