Oil Pan Gasket
Oil Pan Gasket
Postby texaselite » Wed 26.09.2012, 16:41
Mechanic says :
The oil pan gasket is leaky, and it looks like the front subframe will have to be removed to change it.
Will this part work?
http://www.rockauto.com/catalog/x,carco ... ttype,5436
texaselite
Re: Oil Pan Gasket
Postby lotusgirlmarie » Wed 26.09.2012, 18:04
Looks like it will fit though I've never known the 4XE1 motor to have an oil pan gasket. Always just seen them with a lot of liquid gasket like permatex
lotusgirlmarie
Goddess
Re: Oil Pan Gasket
Postby texaselite » Wed 26.09.2012, 18:20
Hmmm..maybe mechanic (not Lotus specialist - mine is only one he has seen) assumed there was a gasket in place.
texaselite
Re: Oil Pan Gasket
Postby Brit-Car-Nut » Thu 27.09.2012, 01:03
There used to ba a tool available from Lotus called a "bead cutter for oil pan". I believe the pans are all glued on with an RTV or urethane sealer.
Return to Engine
