timing belt kit
timing belt kit
Postby Patton » Mon 12.08.2013, 13:38
Hello , were is the best place to get a belt kit for the elan , my local parts place gave up after a while looking
I going to replace the timing belt , water pump, both pulleys and aux belts as well so theres nothing to change for few years and for peace of mind
Patton
Re: timing belt kit
Postby inkitin » Mon 12.08.2013, 14:04
Most owners on here go for the Dayco kit from Rockauto. In the catalogue look under Isuzu, 1991, Impulse, 1.6L L4 Turbocharged, Engine, Timing Belt Component Kit, DAYCO Part # WP169K1A.
Two tips to save you some money:
1. Use the following Rockauto discount code to get a 5% discount.
Current discount code is 104847558619856 and expires on September 1st 2013.
QUOTE:
"Enter the code above in the "How did you hear about us" line of the shopping cart. If you are using our traditional HTML catalog, please click the "Apply" button to the right of the field. Your discount will automatically appear, subtracted from your parts order total. Orders using discount codes must be placed online. Phone orders are not eligible for discounts.
Please note: We sometimes get calls from people who put the word "discount" in front of their code and do not get the discount. Please enter ONLY the discount code, no other words or numbers. Code must be entered before order is submitted to receive discount.
The discount takes 5% off our already-low prices. There's no limit on order size or the number of orders. Use the code for your next order, and share the code with friends, neighbors, relatives, the guy at the corner garage--anyone you know who works on cars or trucks."
2. Try to find at least one other owner also wanting a kit. That way you can share the delivery costs which, for only one kit, are significant.
91 SE Calypso Red
inkitin
Re: timing belt kit
Postby Brit-Car-Nut » Mon 12.08.2013, 14:17
By "both pulleys" I assume you mean the idler and tensioner. You can also get a decent water pump and camshaft end seals from Rock Auto as well. Use the same clasification of the Isuzu, 1991, Impulse, 1.6L L4 Turbocharged and look under Cooling System / waterpump and Engine / camshaft seal.
They don't need seals often, but Rock Auto does carry a lot of the parts for the Isuzu engine the M100 uses.
Re: timing belt kit
Postby Patton » Mon 12.08.2013, 14:58
Thanks for the info and code thats quite a bit cheaper than lotus prices , i was going to change power steering and Alternator belts as well , i am looking on rockauto site but theres quite a few different ones ? any info on which ones are the correct ones to order , my car has no AC fitted
Patton
Re: timing belt kit
Postby ashm » Mon 12.08.2013, 21:28
ashm
Re: timing belt kit
Postby Patton » Mon 12.08.2013, 22:59
Thank you for the info , will order all the bits now and start reading up on how to change the cam belt , fingers crossed all the bolts come out ok :-)
Patton
Return to Engine
