Fredjohn wrote:If it stops when you disengage the clutch, it is unlikely to be the cambelt.
What about the clutch release bearing? This seems a good possibility as it is related to both engine speed and pressing the clutch.
DABgp wrote:I've been told not to worry about the whining, which is worse when the engine is hot. I do worry though...
Brit-Car-Nut wrote:Another consideration is "did the water pump get replaced at the same time"? If yes, which water pump was used?
The water pump Dayco was including in the belt kit had the wrong profile at the belt end - the cogs were square instead of rounded.
See the write-up here: viewtopic.php?f=29&t=22580#p284623
Some people trusted Dayco to provide the correct water pump but that didn't happen.
Now, some suppliers are listing two water pumps as one with square teeth and another with round teeth.
It isn't a huge amount of work to get to the front of the engine. Jack up the car, remove the wheel, remove the wheel arch liner (it should not be a battle this soon after being out earlier),
remove the belt covers and check for over-tightening of the tensioner and also look at the water pump to see if the belt is a really good fit in the drive pulley.
hodge wrote:Alternator and power steering are driven by crank pulley, so affected by engine speed. Put them and their belts on your check list. Alternator bearings possible suspect.
TOWATL wrote:Hahahaha!
I guess I am very lucky, as my girlfriend enjoys the Elan just as much as I do. From the passenger seat that is. So the only noise I hear from her while driving is the occasional giggle of joy.
But I will definitely keep a bottle of wine at hand, just in case...
Cheers guys!
TOWATL wrote:The car is back at the workshop. I had the alternator checked and it works fine. I am pretty sure that the noise is caused by an ovely tight cambelt.
However, on my drive to the shop, the gear linkage snapped!![]()
Now the car is stuck in 5th gear...
It seems I am out of luck this year, as far as my cars go.
Users browsing this forum: AhrefsBot and 3 guests
