GeoffSmith wrote:Randy, I've had a quick look and your temperature is way too high and not regulated at all so your thermostat is probably stuck shut.
The Air Con was definitely blasting the whole time, it was 28°C during my drive.EDIT: The low volts also correlates with the AC clutch so it may not be an issue.
lotos wrote:GeoffSmith wrote:Randy, I've had a quick look and your temperature is way too high and not regulated at all so your thermostat is probably stuck shut.
Wow - glad you saw this, I have never noticed the gauge reading especially hot.
That wouldn't really have any effect on the low power I'm noticing though, correct?
I didn't check the timing yet as John had recommended - would that show in the scan file at all if it were off?
http://www.altitude.org/air_pressure.php wrote:At 5850ft, the standard barometric pressure is 83 kPa (620 mmHg). This means that there is 82% of the oxygen available at sea level.
