Engine problems
Engine problems
Postby besidethewye » Fri 22.08.2014, 14:09
Your advice requested.
After 5 trouble free years with my S2 (~70000 miles) I've had a couple of issues recently.
First lost power (while overtaking up a hill) - engine staggered and engine warning light came on. It didn't happen again and everything seemed fine.
A few weeks but only a couple of trips later I drove 200 miles with no problems - then parked for maybe 4 hours - on return the car would not start. Engine turned over (and over and over) - no sign of catching really. No lights and nothing problematic once it did start - drove back the 200 miles and was fine.
I wondered whether this might be early signs of the cam angle sensor going (based on a hazily remembered read of posts) but I've not tried to really track it down.
I've had a sense of the car being a bit down on power but I don't know if that's real or just reflects the lunatic way that so many others drive these days and how much more powerful modern cars are (though I would not swap!).
Much appreciate any thoughts. I do have Elanscan but not run it in a while and it was reluctant to work last time I tried so might take some attention.
besidethewye
Re: Engine problems
Postby epipete » Fri 22.08.2014, 15:06
Loads of possibilities, but my experiences would lead me to look at fuel pressure as the cause first, can you hear the pump priming when you turn the ignition?
Re: Engine problems
Postby besidethewye » Fri 22.08.2014, 17:57
Thanks -
I started her up - no problem of course but I couldn't hear the pump (which is probably not quite knowing what to listen for and being in a tight garage).
I'll get out for a run over the weekend and see if anything shows up again.
I was thinking fuel when it staggered and would not start - if only there was a carb I might have had an idea what to do....
besidethewye
Re: Engine problems
Postby Rob P » Fri 22.08.2014, 19:15
You mentioned in the first post that the engine warning light came on and then went out, however if that occurred I believe it will have stored a code for that failure and that should be the first point of testing by accessing the diagnostics via the paperclip method if you haven't already
http://wikilec.9600.org/index.php/Check ... t_Problems
simplify and add lightness
1997 Lotus Elise S1 - Metallic Racing Green
Rob P
Re: Engine problems
Postby Simon_P » Fri 22.08.2014, 19:45
I read the first sentence of your post and thought Cam Angle Sensor!
My CAS failed as you describe.
Re: Engine problems
Postby Rice crispy » Fri 22.08.2014, 20:15
Have you checked the wastegate isn't stuck? Wouldn't cause the starting problem but the others could be.
Rice crispy
Return to Engine
