How to crank engine without starting?
Postby atikovi » Tue 15.11.2016, 23:17
If it hasn't been run in a while I like to crank it a few seconds to build up oil pressure. What is the best way besides pulling the plugs wires?
atikovi
Re: How to crank engine without starting?
Postby dapinky » Tue 15.11.2016, 23:51
if you activate the fuel cut-off inertia switch before turning the key to light up the dashboard, then there shouldn't be any fuel getting to the injectors.
That said, there will still be some from last time it ran, but not enough to run very long (or very well!).
For future, it is worth activating the switch before turning off the car so it uses up any remaining petrol (gas!) in the fuel lines...
....oh, and if your memory is anything like mine, put a note on the instrument panel to remind you to switch it back on when you can't start it a few months later!!!
Otherwise, simple unplugging the CAS/ignition wiring will mean it gets no spark (but could lead to other problems with bad connections in the future if done regularly).
There are probably other fuses you can easily remove to prevent the ignition system from firing, but I'd do the inertia switch as it's easy. (on a UK SE anyway - not sure about the FED ones as to how accessible it is).
Postby GeoffSmith » Tue 15.11.2016, 23:53
Pull the fuel pump fuze (A3) - top row, middle 7.5A (red) fuze.
http://wikilec.com/images/9/9c/MJ2-2_Fu ... Relays.gif
Postby atikovi » Wed 16.11.2016, 00:02
Pulled the 10A ECM fuse. That should prevent spark as well as fuel injection.
atikovi
Return to Engine
