Tuga2112 wrote: If your theory is right, I could prime the pump a few times and then take our the spark plugs 1 by 1. If I find a strong smell of petrol when removing one it would be a indication that cylinder injector is stuck open.
Am I correct in this logic?
Brit-Car-Nut wrote:Unfortunately, only if the bad injector is at the cylinder with the currently open intake valve. If the valve is closed, the excess fuel is in the manifold, not the head and you won't get any indication by pulling the injectors.
CalElan wrote:If it was working, and then I do something, and now it isn't working I always double-check what I've just done.
CalElan wrote:Then look at the effects of not running it for a while.. injectors are a favorite here - swapping from the other car is a good idea. How easy is it to do a fuel pressure test on these things? That would give you insight into state of pump and filter. I changed the filter on mine about 2 years back - I suspect it was the first time it had been done and there was quite a bit of crud in it.
Simon_P wrote:Have you checked
Checking CEL
Base timing
Putting it into service mode ie removing sensor input.
That the IAC valve is plugged in and working - pull off a vac hose and the idle may pick up if it does the IAC valve isn't working properly.
All free and easy.
If you can't keep it running to check, slip a piece of thin card between the throttle lever and the stop.
Tuga2112 wrote:CalElan wrote:Then look at the effects of not running it for a while.. injectors are a favorite here - swapping from the other car is a good idea. How easy is it to do a fuel pressure test on these things? That would give you insight into state of pump and filter. I changed the filter on mine about 2 years back - I suspect it was the first time it had been done and there was quite a bit of crud in it.
I fear i cant avoid this injectors swap job. im scared of finding an issue it may be expencive to solve.
) alan e wrote:Or you can do it the easy way by putting a long screwdriver where the spark fits so it sits on the top of the piston and turn the engine via the crank when the screwdriver moves up to its highest point then that cylinder will be at max compression.
Tuga2112 wrote:alan e wrote:Or you can do it the easy way by putting a long screwdriver where the spark fits so it sits on the top of the piston and turn the engine via the crank when the screwdriver moves up to its highest point then that cylinder will be at max compression.
it could be in either max compression. or terminating the exhaust cicle.
thats why the complression tester is helpfull
alan e wrote:You know the firing order so if you start at cylinder one via the crank/timing mark you then move onto the next one to fire and so on for all 4
