Crankshaft Pulley
Crankshaft Pulley
Postby mattdovey » Sat 26.09.2020, 17:30
Evening all,
Does anyone know if the crankshaft pulley is balanced to the crankshaft? Got a pulley that is now all nicely painted. Wont to swop it for the crusty one fitted to the car. I've noticed that the pulley has been balanced and wondered if the pulley was balanced to the crank. I don't want to fit the freshly painted one and find its adding vibration.
mattdovey
Re: Crankshaft Pulley
Postby Simon_P » Sun 27.09.2020, 12:53
You can be pretty sure it wasn't.
It itself is balanced and it is on a keyed shaft so the manufacturing tolerance would be set so that they are interchangeable.
Postby mattdovey » Thu 22.10.2020, 18:12
Pulley fitted. No differances noted. Thanks for the advise.
mattdovey
Postby Critter10 » Mon 06.06.2022, 17:38
Apologies for resurrecting an old post, but does anyone know where I can get a crankshaft pulley for an SE turbo? I've done many trawls via Google and come up blank.
1992 SE Calypso Red
Critter10
Return to Engine
