OIL Info
OIL Info
Postby Elantastic » Wed 05.05.2021, 17:19
Hi All,
I come across an interesting article related to engine oil. I know some of us use a thicker oil due to the higher engine temperatures our cars experience (If we haven't fitted a lower temp fan switch that is) so with that in mind thought it may benefit anyone wondering about if we should use a thicker oil.
:cheers:
https://www.opieoils.co.uk/t-car-engine ... ained.aspx
Elantastic
Re: OIL Info
Postby Rambo » Wed 05.05.2021, 18:12
I have used Petronas 5W 40 fully synthetic oil in all 3 M100's I've owned and never had any problems. I see no reason to make me want to change to a higher viscosity oil. After all an SAE 60 oil is 70% thicker than an SAE 40
An interesting article nevertheless
Re: OIL Info
Postby Elantastic » Wed 05.05.2021, 23:49
Rambo wrote:I have used Petronas 5W 40 fully synthetic oil in all 3 M100's I've owned and never had any problems. I see no reason to make me want to change to a higher viscosity oil. After all an SAE 60 oil is 70% thicker than an SAE 40
Agreed I’m using 0-40 Mobil 1, probably a bit too thin on a cold start and oil pressure is a little lower but no issues thus far.
Elantastic
Re: OIL Info
Postby Rambo » Thu 06.05.2021, 06:00
I'd agree. It comes down to a "what works best for me" approach. You won't go wrong with Mobil, Petronas or any other premium grade oil though
Re: OIL Info
Postby dapinky » Thu 06.05.2021, 11:55
As well as the linked article, there are lots of other 'tech articles' from Opie worth a read (I have just read a few, as I had nowt else to do whilst I had a cuppa!)....
.... as with many such things, most of it went over my head, but a few things make sense.
The discussions on viscosities took me back to 'A' level physics practical where I was given a gallon of oil, and had to drip it through a pipe at various temperatures and plot the results on a graph - but I'm buggered if I can remember what the outcome was, or what it all meant.
I started out thinking that I *may* be causing problems by using 10w60 (Fuchs Titan oil) in my car.... and that the article (and many others) talk about modern engines needing thinner oils.
The more I read, the more confused I became about what is a 'modern' engine - they talk about 'new' engines, designed for thin synthetic oil, and they talk about 'engines from the '70's which required 20w50 mineral oil.
Clearly, "our" engines were designed, built and specified in the 1980's, and to my mind that puts them between the 'old' and the 'new', as they came out when synthetic oil was gaining popularity, and Lotus designated an oil (grade) which suited the engines when new.
The biggest surprise to me was seeing the huge difference when 'cold', vs 'hot'.
From everything I have read, I believe that 0w40 is a great grade for a new (condition) engine, and is probably best for a lower mileage unit, for everyday road use.
BUT
I am currently using 'thicker' oil as my engine has over 140K miles on it, and it appears to keep a good pressure for me and my use.
I tried to find some scientific proof to suggest that I am right to use it, and came up with the fact that I get lower airflow over the sump surface to aid cooling due to having a sump guard, so it will run hotter, and 'need' the thicker oil :? (ignoring the fact that we have an oil cooler radiator).
I have previously used 0w40, 4w40 & 5w30 grades, and didn't feel like I was getting good oil pressure, and may be causing damage (which seems to be correct on a hot engine, but not so great on a cold one)... so I remain confused.
The one thing I am sticking to is that everyone has their own reasons for their choice (even if it's just price/availability, and not science), and my choice may not suit you at all.
I may well try dropping the "W" number next time (but 5w50 doesn't give the same 'pressure' at hot temperatures as 10w60.... but is 'better' at cold) as I've not used it before, but probably wouldn't go to a 0w40 as it didn't seem so good in my engine last time I used it.
Basically, if you stick to a good oil, somewhere close to the specs, it is a good starting point, and then try a grade in either direction and see how it feels for you and your engine, with the use it gets.
Opie (and other good suppliers) will happily give you a base recommendation for your own circumstances.
(Certainly, with the T5 there are more opinions on the forums than members, but I always use Quantum 507 and it hasn't blown up yet, likewise in the Vauxhall I stick to GM oil, and in the Triumph, it's good old Castrol GTX 20w50)....
Re: OIL Info
Postby Elantastic » Thu 06.05.2021, 14:53
That’s interesting as I also notice good pressure at cold but lower when it warms up, I’m currently running a lower temp fan switch so decided to use the 0- 40 oil as like you say it works extremely well in newer engines and I have been impressed with it. From a mechanical point of view how Much different could the mechanics be inside a newer engine ? Open to anyone’s thoughts.
Elantastic
Re: OIL Info
Postby rip » Fri 07.05.2021, 13:57
I remember we had a contributor on here who really didn't like oils with big differences between cold (Winter) viscosity & running viscosity because these contained more/stronger additives to reduce thinning as the oil warmed & these compromised its lubricating properties. I can understand the logic of that.
Our oil pressure gauges are useful so there is a little less guesswork as to how the oil is actually performing.
Return to Engine
