Hector2021 wrote:Have you tried with a listening rod to your ear to locate the exact area the sound is coming from?
peteoddcar wrote:Did it suddenly start or gradually get worse?
I had a whirring noise with my car after a cam belt and water pump change and that sounded like it was from around the CAS. The CAS plastic cover acts a sound box.
After a lot of fiddling and trying different diagnostics it appears it was a bad water pump drive gear.I sort of had to be something to do with the cam belt job as it was fine before.
It’s quite easy to check the CAS drive to eliminate or fix, I think if that all looks good then take a look at the cam belt tension - follow the procedure to check and set in the Wikilec.
lotustonybassplayer wrote: i seem to remember somewhere that someone mentioned if the cam belt isnt tensioned correctly it can cause some sort of fluttering.
a finger calibrated beforehand by pressing down on some scales and a steel rule with tape on it which sits behind the beltTanz wrote:Do you guys actually use a 10kg weight or just finger pressure
