Replace head gasket and what else
Postby M100Brisbane » Thu 07.08.2025, 01:57
So the M100 gods have not smiled again, and I have a head gasket failure.
Before I start ordering gaskets and stuff, what else should I be attending to while its in pieces.
I'll certainly do the timing belt, water pump and idlers.
Also Cam angle sensor seals
Should I have the injectors cleaned?
What else?? Coolant hoses are two years old.
Gratuitous pic to cheer everyone up - mine is the black one.
Thanks in advance
Michael
Brisbane - Australia
Elan M100 S2
Europa S2
M100Brisbane
Re: Replace head gasket and what else
Postby Tuga2112 » Thu 07.08.2025, 09:40
depending on how you disassembly the whole shebang.
if i had to do that again.
I would consider changing the IAC valve. (assuming you can get one for 10-15 quid (gbp) as they are unique to the M100 but not. because the vauxhall part does the job, but the plug is hell to install.(and with the head out its a dodle)
also refurbish the turbo, since you gota take the exaust manifold out it will be a dodle to get the turbo (and heatshields) sorted
Return to Engine
