sump stumped
sump stumped
Postby stevo » Mon 31.10.2005, 18:12
i cant see how to get the last 2 sump bolts off. if you have done it before you will know what i mean. :(
stevo
Postby Doug » Mon 31.10.2005, 19:15
Dave M just did his so he can probably help . . .
Re: sump stumped
Postby Monty » Mon 31.10.2005, 19:19
stevo wrote:i cant see how to get the last 2 sump bolts off. if you have done it before you will know what i mean. :(
I`m not sure stevo but do u need to take of the guard off at the bottom of the gearbox :idea:
sump removal
Postby Mike_H » Tue 01.11.2005, 06:33
Stevo,
I've just removed my sump and I took this photo of the big bolt that you will have to remove along with a few smaller bolts to take the black guard off the gearbox.
Mike.
Mike_H
Postby Scott J » Tue 01.11.2005, 13:11
Stevo,
doesn't answer your question but I had a holed sump. Was in kenny B's 2 weeks ago and he welded it up in situ, reckoned it was a damn site easier than removing it.
Scott J
The prodigal son
Postby davidjt » Tue 01.11.2005, 14:36
Interesting: I was worried when I first got the car that the sump was vulnerable on the atrocious roads in rural Kent; no-one else seemed to have a problem, but after touching the road once or twice I fitted a crude sump-guard (angle-iron!). Ten minutes on a ramp, and twelve months' peace of mind, so far.
davidjt
Postby Scott J » Tue 01.11.2005, 15:10
David, My mechanic had the same problem with a previous Elan, apparently the sump is double skinned, lotus must have known it was vulnerable. So yours is now triple skinned :wink:
Scott J
The prodigal son
Postby Mike Y » Tue 01.11.2005, 16:17
Yes I am affraid the clutch cover does have to come off, I have just done my S2 fortunately I also had removed the Prongerone (engine under frame T shaped) which made the job very easy. By the way removing and re fitting the prongerone is very easy also.
Good Luck.
Regards Mike :D
Mike Y
Postby Exbury » Tue 01.11.2005, 17:12
One thing I have always wondered, is if you get a holed sump by a speed bump when travelling at the posted speedlimit, can you get it back off the highway department or council (depending upon ownership) if the car has not had any part of the suspension modified. As the risk of engine destruction is seconds away from any major hole to the sump, its always worrying when going over the bumps!
Exbury
Postby Paul.P » Tue 01.11.2005, 21:18
I believe speed ramps are only supposed to be a certain height, & i think its 80mm. I do know a neighboor who had his exhaust damaged on a speed ramp & the local council did compensate him, coincidently it wasn't long before that particular speed ramp was altered !
Postby Scott J » Wed 02.11.2005, 12:52
I heard speed bumps were 5" which ties in with your metric 80mm Paul.
Scott J
The prodigal son
Postby Monty » Wed 02.11.2005, 12:55
Scott J wrote:I heard speed bumps were 5" which ties in with your metric 80mm Paul.
Scott u need to go back to school, 5" is more like 125mm :roll: :poke:
:wink:
Postby Paul.P » Wed 02.11.2005, 20:25
I will ask the question, i know someone who works in planning, although knowing this country, different councils will have different rules. Will let you know !
Postby stevo » Thu 03.11.2005, 01:51
aaaaaaaa, the prongerone has to come off first. now i see. thanks for the help. :D
stevo
Postby Scott J » Thu 03.11.2005, 11:24
Stevo, yup, need to take the prongerone off, which is another reason why KB didnae remove my sump, sorry should have mentioned that, thought you knew it.
Monty, point taken, I must have been sleeping. Though I stick with my 5" / 125mm bumps, have you ever seen one as low as 80mm (80mm is what your pam and 5 sisters get a grip of :lol: :poke: - it must be true cos Dico told me :wink: )
Scott J
The prodigal son
Postby Monty » Thu 03.11.2005, 17:42
180 in the droop position :bananasex:
Postby Paul.P » Thu 03.11.2005, 18:43
Not that it makes ant difference, but prongeron has no E on the end.
Postby Doc Fizzix » Thu 03.11.2005, 19:43
Monty wrote:180 in the droop position :bananasex:
LOL :lol:
That is the best use of the bananas I have seen, you got to love the poor fellow in the front taking it as well as he does
Doc Fizzix
Postby Mike Y » Thu 03.11.2005, 20:42
Dont worry about removing and re fitting the prongeron its really easy!
Six bolts and its off. As long as you have all of the front of the car off the ground the raft's stay in place and you slot it back in. Exhaust down pipe was already off my car that could be something else to be removed you might just get away with it but I doubt it.
Regards Mike
Mike Y
Postby Dave M » Tue 08.11.2005, 22:14
Doug wrote:Dave M just did his so he can probably help . . .
He would if he'd check all the threads... :roll:
Looks like Stevo's got it...and that mount is a bugger if you attach the thing in the wrong order after say a transmission removal. Not that I'd know or anything...
Dave M
Return to Engine
