cant get elan scan working
Postby addict » Sat 20.11.2010, 16:43
elan scan wont work for me .
ihave a recent laptop and down loaded both thr versions of elan scan from the site.
plug the lead into car and laptop start prog pc asks for elanscan interface drivers ?
i have selected all comms ports manualy 1 throu 20 still not communicating just comm port not found or inactive....
what am i doing wrong ?
addict
Re: cant get elan scan working
Postby GeoffSmith » Sat 20.11.2010, 16:54
Follow the instructions here:
http://www.lecinterfaces.talktalk.net/U ... lation.htm
EDIT: Updated link to new site
Postby addict » Sat 20.11.2010, 18:01
cool got that working went for quick run in traffic no clear roads here how do i post the results ?
addict
Postby GeoffSmith » Sun 21.11.2010, 17:40
Do a run from cold (see Wiki), save the file (as a .ecu), zip it and upload it onto the forum.
Postby addict » Sun 21.11.2010, 20:09
zip it you mean save it to a zip file ?
sorry mate heating engineer not a it savy bloke
addict
Postby GeoffSmith » Sun 21.11.2010, 20:54
Yep. Forum won't accept .ecu files but will take .zip files!
Postby lotusnut » Sun 16.01.2011, 20:07
Geoff, are the above download instructions ok for Windows 7?
Merv
lotusnut
Postby Ted » Wed 01.05.2013, 15:09
I do have the same problem (comm port inactive, I'm running Vista), but Geoff the link you posted doesn't work anymore
Ted
Postby lotusnut » Wed 01.05.2013, 19:55
lotusnut
Postby Ted » Thu 02.05.2013, 06:35
Thanx. I finally did it. But I have the "bad echo".
Ted
Postby Brit-Car-Nut » Thu 02.05.2013, 15:06
Just a note: the ALDLINTERFACES website is moving. Don't be alarmed if you can't get to links found in this section, Geoff will post new links soon, hopefully later tonight.
REMEMBER: You should not have the interface plugged in while you are installing the drivers. For XP, if you plugged in the interface and Windows tried to install drivers, then go into Device Manager and remove the broken driver. It probably will be at the bottom with a big yellow question mark. Just right-click on it and select uninstall. For the newer Windows versions, the process is similar but I don't know the specific steps.
Try this link: http://www.alanmcnicol.dsl.pipex.com/US ... tions.html
To get the NEWEST FTDI drivers go to http://www.ftdichip.com/Drivers/VCP.htm and download the executable 2.08.28 WHQL Certified driver.
The executable is http://www.ftdichip.com/Drivers/CDM/CDM20828_Setup.exe Download this, don't run across the web. For XP, this should be able to run by right clicking it (after downloading it) and selecting "run as". For Windows Vista, Win7 or Win8 you probably should use the run as admin/supervisor option. I don't have Win7 installed anywhere but installing drivers requires admin rights.
Postby GeoffSmith » Sun 05.05.2013, 20:57
New site: www.lecinterfaces.talktalk.net
Don't forget the Wiki for help.
Return to ElanScan
