by GPT27 » Wed 20.12.2006, 20:22
Geoff,
Received with thanks.
I've just made a transfer to your account. I've made it £16.78 to distinguish my payment from others.
Thanks again for your work.
GPT27
by GeoffSmith » Fri 22.12.2006, 14:52
Grant, thanks for that.
Bob, payment received thank you very much. I'll forward the extra on to Stevo.
I hope everyone has received their interface by now, however the mail has been a bit hit-and-miss around here. Let me know if nothing turns up.
Merry Christmas to everyone and thanks for your patience. USB's should be ready in the New Year.
Geoff
- Kitty Fiddler
by Bobc » Fri 22.12.2006, 17:11
Hi Geoff,
Mine has not turned up yet, probably the mail?
I will let you know if it does not arrive by the new year.
Thanks,
Bobc
- Tinkerer
by Bobc » Wed 27.12.2006, 12:44
Hi Geoff,
Arrived yesterday, many thanks.
Bobc
- Tinkerer
by GeoffSmith » Thu 28.12.2006, 16:23
Grant - payment received thank you.
- Kitty Fiddler
by ailwyn » Fri 29.12.2006, 11:11
Geoff,
Did my sex-changed interface get sent out? Let me know what the cost is.
Also have you had a chance to look at the instructions for my "kit"?
Ailwyn
- Forum Member
by GeoffSmith » Fri 29.12.2006, 12:30
I've been press-ganged into a spot of decorating so it's still only half built I'm afraid and I still haven't put together the build instructions. I'll see what I can get done over the weekend.
Geoff
- Kitty Fiddler
by ailwyn » Fri 29.12.2006, 13:03
No problem, just though the postie might be on strike
Interface would be first choice if you could squeeze it in.
Ailwyn
- Forum Member
by GeoffSmith » Mon 08.01.2007, 00:51
Ailwyn,
It's almost ready - I had forgotten to reverse the order of the pins (because it's male) so I've had to mount the plug upside down and adapt the connections to the pcb! A couple of questions before I finish however:-
1. How long do you want the lead from the unit to the ALDL plug?
2. Do you need the retaining screws? The reason I ask is that one of them hasn't had a thread cut!
I can get a replacement from Farnell but it will hold things up.
Geoff
- Kitty Fiddler
by ailwyn » Mon 08.01.2007, 00:56
geoffsmith wrote:1. How long do you want the lead from the unit to the ALDL plug?
best make it standard length, as for the moment it will have to sit on the seat.
geoffsmith wrote:2. Do you need the retaining screws? The reason I ask is that one of them hasn't had a thread cut!
I'll live without it, one should be enough for what I want (assuming it ever gets used).
Cheers Geoff, your a star.
Usual fee or do special requests come at a premium?
Ailwyn
- Forum Member
by GeoffSmith » Mon 08.01.2007, 01:43
Ailwyn,
It's ready.
I can't lay my hands on any ribbon cable to make up a test lead at the minute. I'll try and get it done tomorrow and post it to you on Tuesday.
As long as you tell us what you're up to, I'll let you off the development cost, so it will be a standard £15 + £1.77 P&P.
Geoff
- Kitty Fiddler
by GeoffSmith » Mon 08.01.2007, 22:44
ailwyn wrote:geoffsmith wrote:2. Do you need the retaining screws? The reason I ask is that one of them hasn't had a thread cut!
I wasn't thinking straight last night.
Thinking about your sex change business, the female should have screws but the male should have captive nuts if you get my drift. Consequently, I've put some nuts on and you shouldn't need the screws, unthreaded or otherwise (but I'll stick them in anyway).
Off to the garage to test your sex change with the short bender I've just knocked up.
Geoff
- Kitty Fiddler
by GeoffSmith » Mon 08.01.2007, 23:42
Ailwyn,
Success! I'll try and get to the Post Office tomorrow.
Geoff
- Kitty Fiddler
by ailwyn » Tue 09.01.2007, 00:26
Will let you in on what I'm doing after I've tried it.... not sure that it'll work, but hey, what the hell
- Forum Member
by GeoffSmith » Fri 12.01.2007, 21:04
Ailwyn,
Posted late Wednesday so you should have it by now.
I put in a 3 way pcb terminal block for your DIY interface as well. All you need now are some build instructions I guess!
Geoff
- Kitty Fiddler
by DeanG » Sun 14.01.2007, 22:26
Waiting with fish baited breath? I'm hoping the USB cable will come soon so I can figure out an intermittent problem that has eluded two shops so far.
DeanG
DeanG
by GeoffSmith » Mon 15.01.2007, 00:00
DeanG wrote:Waiting with fish baited breath? I'm hoping the USB cable will come soon so I can figure out an intermittent problem that has eluded two shops so far.
DeanG
Dean,
I hope to get back to the USB development in the next couple of days. I have a working prototype which I am in the middle of refining to ensure it works for everyone under all conditions but decorating duties have halted that temporarily. As you are having problems, I've put you top of the list so you should get one as soon as I have completed development.
Geoff
- Kitty Fiddler
by DeanG » Thu 18.01.2007, 02:23
It wasn't my intention to sneak up the list... but thanks. Driving back home from the shop (427 miles) the CEL came on repeatedly between 37 and 81 miles then didn't show itself again untill about 300 miles. The distance to good mechanic is is one of the reasons it can be challageing to drive an M100 in the USA.
DeanG
by paulwatkins » Fri 02.02.2007, 12:42
Hi Geoff,
Witht he hope of the impending start-up going ok this weekend, I would like to obtain one of your interface cables please.
usb or serial, it doesn't matter, whichever is easier for you.
Cost details pls?
Cheers, Paul
paulwatkins
by GeoffSmith » Tue 20.02.2007, 19:29
Gazza,
Service mode plug send first class yesterday.
Geoff
- Kitty Fiddler
Return to ElanScan
