Donation to forum paid for help reading Elanscan o/p
Postby ailwyn » Thu 17.07.2008, 19:22
Can you post some pics of your engine bay:
1. The bit between the coolant header tank and the engine where is says DOHC
2. The pipework at the back of the black dustbin airbox
Postby RayD » Thu 17.07.2008, 20:06
Andrew,
Before you start changing the leads...If it’s still on three cylinders re-check the spark plugs. Change the ‘faulty ‘one over to a different cylinder and see if the problem follows it.
Postby Doug » Thu 17.07.2008, 21:08
ailwyn wrote:That's a dump valve.
or a scared descendant of your mouse friend :-D
Postby andrewrenouf » Thu 17.07.2008, 21:31
Thanks RayD
Yes I never thought of that. I suppose I could remove one lead at a time and when I remove the lead that's "missing" it won't get worse. That would narrow things down.
BTW everybody agrees the noise is my dump valve but what does the super increase in noise signify? Has my dump valve silencer fallen off!!!!!!!!!!! (only joking!)
Also, this is a thick question but what's a dump valve?
BTW Ailwyn I'll take some pics of the engine bay as you ask tomorrow as it's dark outside!
Thanks - Andrew
andrewrenouf
Postby ailwyn » Thu 17.07.2008, 22:29
andrewrenouf wrote:Also, this is a thick question but what's a dump valve?
All questions here are valid (unless they are asked by Gary).
When you are on boost, the turbo is spinning and forcing air into the system, when you let go of the throttle the engine suddenly stops using the air but the turbo is still spinning and pushing air into the system. This would normally cause the turbo to stop suddenly once the intake is fully pressurised.
A dump valve is a pressure release that opens when the pressure on the intake goes higher than would normally be expected on boost, thereby releasing the air that was forced in by the turbo when the throttle is closed, and allowing the turbo to spool down naturally, without the stall.
The pics you take of the engine bay should show whether a pipe has come loose from the dump valve.
ALL FIXED!!!
Postby andrewrenouf » Fri 18.07.2008, 17:31
Dear All
It's all fixed! Thanks very much for your help!
It turned out that the excessive dump valve noise was due to the big rubber pipe which had fallen off from the turbo input!! (How stupid not to spot that one - but is was quite a new noise so I hadn't investigated that much!)
The misfiring wasn't related to the above but was later fixed with a new set of leads from SJ Sportscars which (although a bit expensive), turned up the next day in the post so good service from them.
It was really handy that people looked at the Elanscan output as the paper clip test gave a CTS error code (perhaps it hadn't cleared from when the CTS was changed literally an hour of driving time before). This input from people saved me time going down the wrong path and messing about with the CTS.
Again thanks all, the Sun has been shining in Jersey and now the tyres and brakes are all very smelly!
Thanks again forum - a great response and well worth the £ 20 donation to hosting expenses!
Best regards - Andrew
andrewrenouf
Postby GeoffSmith » Fri 18.07.2008, 17:45
:smt023
Also confirmation that your donation has been received, thank you.
Postby Gary » Sat 19.07.2008, 09:25
Andrew,
What colour is your car - saw a BRG and a metalic blue in Jersey in May ?
Postby andrewrenouf » Sat 19.07.2008, 10:38
Hi there
It's red with peeling lacquer. You wouldn't have seen it as it's been broken down since February!
Thanks - Andrew
andrewrenouf
Return to ElanScan
